- 23 Mar 2010
hi,
basically i want to know which is the best java software to use for creating and editing Java SE
by the way, im a beginner at this so, i want to know from 'experience' which is the best java editor that will suit me.
in uni, i used TextPad, but apparently there are errors in that software (that randomly creates unknown characters) and causes more errors the more you'd compile it. therefore i dont wanna mess with it while completing assignments.
ive randomly tried netbeans, which was a waste of time because i cannot run java files unless they are created in a project/project forlder or whatever.
also looked at that sticky on OC forums. but have no clue which are better =/
any help?
thanks..
any help?
thanks..
