Best Keyboard and mouse combo?
Caporegime
12 Mar 2004
England
Can anyone reccomend me a decent wireless mouse and keyboard combo for <£50?
The logitech ones seems to all have half size enter buttons and there isn't the usual 3 column 2 row set of keys to the right of it.
I was using the logitech laser mx3200 set, works well and i find the logitech mice more comfortable than microsoft ones but really its personal opinion, try before you buy if you can.
At £40 I was considering the mx 3200, however it appears from the logitech image gallery and the ocuk website to have an american keyboard layout ie a half size enter button with the \ symbol above it, can you confirm?
I dno if it helps but I just looked at the G15 gallery on their website and its the same and Im sure it comes with a normal enter key if you ensure you are getting the UK spec version. Those images just seem to show the generic USA product unfortunately...
Why dont you webnote OcUK and ask?
ps3ud0 :cool:
