Best Keyboard For FPS?
I recommend this keyboard it's the Gamdias Hermes. As I've mentioned to others, managed to get my hands on one of these at i-Series after using a Ducky Shine keyboard. This keyboard's pretty big, nice wrist rest and just solid build all round.
not sure how i can help on this one as most keys on decent keybaords are the same size as the ones on the K60.
Mechanical keyboards then something with Cherry reds would be my recomendation.
None mechanical Logitech G610 or something similar.
A fairly big mech keybaord is the Razer Black widow Ultimate. Personally i would spend my money on a reduced Ducky over a black widow but you may find it more to your taste if you are having particular trouble with the K60
Thanks for the replys
Yes a might try the ducky keyboard
The K60 is a nice keyboard, also does anyone know where to get the key tool from to remove the keys as ive lost mine :confused:
