My other half is looking for a good Nikon zoom lens for landscape photography - the ability to use in street/city photography would also be ideal. She currently has a 50mm prime which is just too zoomed. That and the 18-55mm prime isn't the greatest for quality.
Trouble is, I'm not sure what to advise here. I'd have thought a 17-50mm but would a wider range be ideal e.g 10-100mm? Although, you'd presumably have to put up with a loss of quality in the latter?
We're going to Finland/Lapland in December, it would be great to take in as much of the scenery/landscape as possible.
