best laptop from ocuk?
13 Jan 2004
Leicestershire
hi i'm after a budget laptop that i'm thinking to replace my pc. will be used for internet and office stuff.budget is around £400 tops.
i quite like the look of the samsung nc10 atom, is this ok?
Its a good machine but they are really small, if i was you id go down to one of the high street shops that stock them and have a look first to see whether you think you could get on with it before ordering, a lot of the mobile phone shops have them now so its worth checking out.
Ive got a netbook and its handy to use, but i couldnt use it all the time as my main pc.
The NC10 is a great little machine but if you are going to do a lot of typing (whilst using a desk) then I'd budget for a keyboard as whilst the NC10 keyboard is very good it is small and you won't be able to type quite as quickly as you would on a full size one.
I'd still recommend it though, great machine for the price!
