Best Light weight cd/dvd program
5 Jun 2005
Southampton
i loved nero, but like winamp and other greta programs it got 'big' and bloated, so what else is out there for the man that likes things simple and lightweight?
beh said:
CDBurnerXP is quite good. New version is a long time coming though.
A flipping long time coming.:rolleyes:
bledd. said:
imgburn
problem solved
Yup. Tried it out at bledd's suggestion and it is brilliant. My main need for a burning prog is to burn nLite ISOs and everything else I could conceivably use the built-in XP burner so unless the new CDBurner turns up fairly soon and is easier to burn bootable ISOs than the current version I might get rid of CDBurner.
Just burning a DVD under Windows Vista using CD Burner XP v4... Seems good so far!
Edit - All complete. Works fine, good free little program.
infrerecorder will be awesome when it supports more dvdrw drives, i've had it not recognise two now
really sleek software though, how burning tools should be!
