How does Arch compare to Gentoo?Una said:I would say Ubuntu is the best for a beginner. I run archlinux which is ideal for what I use it for though. I can highly recommend it if you like a more tuned distro optimized for 686, which does not install the kitchen sink by default. Takes some time to configure it to how you like it though.
Dj_Jestar said:How does Arch compare to Gentoo?
Energize said:Sounds like unbuntu then.Can you encrypt the linux partition with aes so you need a password to start up the os? What sort of security features does linux have compared to windows, and whats the system performance like?
