Best liquid cooler?
8 Mar 2011
So I got myself a corsair 750D case and surprised to learn the XSPC 5.25" D5 Dual Bay Reservoir and Pump Combination wont fit it. So im going down the route of a liquid cooling like the likes of Corsair Hydro Series H100i for my i5 4670k cpu
So what is the best liquid cooler that has the best performance and dead quiet?
TBH the h100i or NZXT kraken would suit you fine. no need for the fathom unless you want bling bling
Hello mate,
I have recently got my 1st WC build going and I used an EK L120.
This should fit your case and will offer a custom loop. It has a 120mm Rad.
My case is the 800d which fits nicely. Performance is excellent, I have heard things about the H100i that arnt particularly savoury-especially for the price. I got the EK kit for around £130 delivered.
I would seriously check it out for the price. You will get considerably better performance than an AIO.
Here is a link (I didnt buy it from OCUK however).
http://www.overclockers.co.uk/showproduct.php?prodid=WC-343-EK
