Best Low Budget Processor?
8 Mar 2011
I am torn between 2 Processors:
AMD Athlon II X3 Tri Core 455 3.30GHz
AMD Phenom II X2 Dual Core 555 3.20GHz Black Edition
Which is best with Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard?
Thanks
depends what you plan to use it for, but personally would chuck another £10 into the mix and get Phenom II X4 840, but thats just me!
yeah also why not consider a second hand Core II Quad, they are still better than Athlons and at least equal to Phenom IIs, plus they tend to overclock quite well. ;)
