Best low profile LA775 HSF? <100MM
18 Oct 2002
UK
I've got an Asus P5K-VM with a Q6600 in a Thermaltake LAN case with only 100MM clearance to the bottom of the PSU (solid side of PSU no vent there)
I'm on the stock cooler at the moment but would like to upgrade, best I can find currently is this http://www.overclockers.co.uk/showproduct.php?prodid=HS-050-AR
Which is good as it's cheap as well! I don't want to squeeze in the biggest cooler I can, just something semi decent.
What is out there I'm missing? No room for a H80 type cooler as rear exhausts are 2*60MM wheeny things and no room to mod in something bigger.
Small, cheap, with a bit of muscle?
Oh and doesn't have to be quiet, just 'normal' it's a games box :)
Yeah, I came across that site. Realised their best pics are all 120MM fans, even horizontally they won't fit in my case sadly.
I ordered a Scythe Samurai ZZ in the end, hope it turns out to be ok (should be!) not many 92MM options. But it looks decent and has a good pedigree!
