Best LR2 plug ins
22 Apr 2009
Birmingham
Recently bought Adobe lightroom and so far it is very good. Thought i'd expandit a bit by trying some of the plug ins, Which ones are highly recommended?
Just tried the Flickr plug on the trial basis, but as its so cheap to buy the license i think i will.
But can't actually seem to get the plug in to work, anybody care to give me a lowdown?
Have you installed it correctly? File > Plugin Manager > Add?
Then to use it, Export > Then at the top where it says 'Files on disk' click that and you will see a small drop down, select 'Flickr'.
is the flickr plug-in any faster than flickrs stand alone up loader ?
i only get about 50kbs when using there own up loader and when you have about 100 pics this takes ages to do.
