Best matx case
22 Oct 2004
Don't want to pay any more than £200 for a case. I like the look of the phantek enthoo evolve, I currently have the itx version.
I also like the look of the Corsair 280x.
I want a case that fits an aio cooler and the biggest gpus.
I'm currently using a Phanteks Enthoo Evolv M-ATX case with a 280 aio in the front.
There is about 20-25mm between the front aio fan/rad and my EVGA 2080 ti black.
Is a very nice case, but can get bit toasty depending on what hardware you run in it.
Thanks Vin, yeah I like my enthoo. My GPU and CPU are both under an aio so temps are pretty cool. Wanted to do the same in an matx build except the GPU will probably be a beefy third party cooler as soon cards seem to be a bit thinner on the ground.
Also wanted a case that looks a bit nicer with some RGB as it's going to be hooked up to the living room TV.
Here is my current Phanteks Evolv m-atx setup, soon to be moved to a Lian-Li O11 dynamic for full water cooled setup
