Me primarily. Bit of both, will be for emulation, some video editing and some emails.
Cool, so your choices are (imo) a blue or brown switch equivalent.
The blue is a 'clicky' switch, which makes a noise and gives tactile feedback when you reach the actuation point of the switch. People around users tend to find them bothersome, hence why I asked about 'other people'. Not amazing for gaming, considered the best for typing.
The brown is a 'tactile' switch, essentially a blue without the 'click'. It's more of a 'bump' over the actuation. Some people think it's too bland. It's generally considered the 'middle of the road' switch. It's my favourite (well, tactile ones are, there are hundreds of niche variations aside from the basic browns).
My subjective recommendation is for a brown switch, TKL or 75% board
(TKL means tenkeyless, better ergonomically if you spend time at the PC and aren't inputting numbers all day. 75% is similar, it's just more scrunched together)
The cheapest keyboard with most of your spec on OC
is this, which is above your budget. As your budget grows, the field widens dramatically
I suggest searching around for something with brown mechanical switches (there's a Drevo 75% one with Outemo browns I found that would be a cheap way to try it out)
If you eventually decide you like it, post on here and we'll give you some aftermarket keycap recommendations
