Best memory chipset for ryzen
Strongly recommend the 8-Pack TeamGroup Dark Pro memory, the 3200Mhz CL14 version is the best.
https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
Slightly cheaper option is 3000Mhz CL15:
https://www.overclockers.co.uk/team...nel-kit-black-grey-tdpgd416g30-my-072-tg.html
Otherwise look for Samsung B-Die but make sure you go for the lowest latency possible for the speed. Generally CL14 will be the best binned Samsung B-Die.
If you want RGB the G.Skill Trident Z RGB or Corsair Vengeance Pro RGB and get CL14 if 3200Mhz, or CL16 if it’s a higher frequency.
