Hi,
I've been looking at these tri channel 6gb ram kits:
Corsair Dominator GT 2000C8
Corsair Dominator GT 1600C7
Corsair Dominator 1600C7
I'm wanting to oc my i7 920 to the 4ghz range, and i know higher ram clock speeds don't give much (if any) performance boost
Would it be worth while to buy the 2000C8 and underclock to 1600 to reach tighter timers (possibly C6) as the 2000C8 is cheaper than the 1600C7, or would it be best to go for the lower priced non-gt series 1600C7 or possibly the Corsair XMS3 series, or maybe OCZ although i prefer corsair to ocz
I also may upgrade to 12gb in the near future, so the best cost to performance ratio will be best
Any help/suggestions appreciated
Thanks in advance
Thanks in advance
