- 6 Jan 2013
- Rollergirl
I'm going to be adding an additional GPU into my loop, so I'm thinking I might as well vacuum the rads and fans and generally perform a bit of maintenance.
What's the best method for flushing any crap out the loop? I'm thinking just fill with de-ionised water and drain a couple of times before adding the Mayhems, would it be that simple?
I don't intend to replace any hoses or fittings as the loop has only been installed for about 8 or 9 months.
