Best method to remotely access a network?
22 Jun 2021
UK
Me again!
I have a laptop on the go and i keep needing to upload or download files that are stored on the server at home. I was going to use third party software like FileZilla but I would prefer a built in Windows method if it's more straightforward.
Thanks.
OneDrive is a possible solution. Log in on both Server and Laptop - move files into OD folder and then access from both locations
Issue there is it doesn't directly put it on the server. I'd still have to go home and transfer them.
I think whatever you use your going to need physical access to your server to set it up. If your on site then Dropbox/Onedrive etc should do it.
If you can gain access from outside without allowing it server side then so can a hacker
Run a VPN and file server on your network.
That give you native file management with no additional client tooling (other than VPN client, which is built into windows I think anyway).
You simply mount a network drive once connected to your VPN.
Thanks
there are things like AnyDesk / TeamViewer to simulate the physical access.
if your happy to self host then rustdesk as an exmlple, with a control/relay node in the cloud.
use the above with onedrive as well.
onedrive vs vpn : if the conenction drops on vpn then you might need to start over. with onedrive the sync may lose a few bytes of date but it will pick up from were you got of.
could look at something like "NextCloud" "Syncthing"
were you control a lot more and only what you want leaves the network. use inconjunction with vpn.
how much do you want to learn and tinker with vs "it just works" style approach
