- 30 Aug 2014
I have one of these but it doesn't fit my S23U even though it's the largest size:
It's also broken once so I had to put bolts through it to repair. The ball joint is all plastic so will break again given time.
Anyone know of an alternative which is actually made from metal and won't break?
Also with the ability to mount it on squarish frames and not just round ones?
Thanks
Thanks
