CPU:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-367-IN&groupid=701&catid=6&subcat=1671
RAM:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-104-KS&groupid=701&catid=8&subcat=1517
Motherboard:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-GI&groupid=701&catid=5&subcat=1990
If you can stretch the budget a little, go for this motherboard instead, as it is more future proof being Gen 3 with PCI-E 3.0 and support for Ivy Bridge, plus the bonus of onboard 8 Channel HD Audio with THX TruStudio Pro instead of typical Realtek:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-192-MS&groupid=701&catid=5&subcat=1990
Thanks, so is it worth going intel no matter what then?
I would like to do some mild overclocking but don't want to spend much on a motherboard, is there anything good for a bit less, preferably asus?
Do t think you can OC the O2 2100![]()
With this kind of budget is intel really the best option, if i can get similar or better performance to the i3 2100 from amd with some oc?
The 965 is about the same price and gets similar results on benchmarks, sometimes behind, sometimes in front. They're older and hotter and more power consuming CPU, but they are still good if you want a budget quad. That being said AM3 mobos are about £40, but the i3 has a miles better upgrade path.
I tend to find that when it comes time to upgrade i end up having to buy all new bits anyway so i might go for amd if it saves me a bit.
Bulldozer is clock for clock SLOWER than it's predecessor Phenom II X4 on gaming, so don't bother.What about the new AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz, it's about the same price?
It would depends on how high-end your graphic card(s) is (are). Generally speaking, for graphic card with only a single GPU (even GTX580), the i3 2100 won't not bottleneck it in FPS games...but the i5 2500K might offer slighting higher minimum frame rate due to its larger size (3MB vs 8MB) cache, rather than its extra cores. But for games that are extremely CPU demanding that can have ridiculous number of things on screen (i.e. Total War series, WOW), then the i5 2500K's ability to overclock to 4.6GHz might make it deliver better frame rate than the i3 2100, if if thoses games would use 4 cores, the extra cores on the i5 2500K would help as well. WOW for example, the game is know to be extreming CPU demanding, yet the game would pretty much use just ONE core for rendering, so if comparing i3 2100 to a i5 2500K overclocked to 4.6GHz in this situation, it would be pretty much like comparing a single core CPU at 3.1GHz to a single core CPU at 4.6GHz, so the performace different can be quite huge. But most games in general would use 2-3 cores now, and with big name titles using 4 cores or more.Just one last quick question, how much difference is there between the i3-2100 and the i5-2500K for gaming?
