best mobo/cpu for antec micro fusion ?
28 Jul 2004
llanelli , south wales
need a few recommendations for this case as i bought it a few days ago from here ( first part of build )
to be many used as media centre .. with some light gaming ( old et ) tribal wars .. no real advanced games except the odd play of half-life 2 .
using a dell 2408 .. but will mostly used for hd/blu ray playback ( once i get aroudn to it )
hdmi is i would say is a must, unless someone can give a good reason for mobo not to have one
any help would be great
Well it would depend on your budget, but sometthing like this
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail £149.49 (£129.99)
Asus P5Q-EM Intel G45 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard £106.94 (£92.99)
Sub Total : £222.98
Shipping cost assumes delivery to UK Mainland with:
DHL @ Home Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £7.99
VAT is being charged at 15% VAT : £34.65
Total : £265.62
If you need cheaper you could drop the CPU down as far as an E5200 if you wanted, though obviously you are losing performance in doing so
what about :-
Gigabyte GA-MA78GM-S2H AMD 780G Micro-ATX (Socket AM2) PCI-Express DDR2 Motherboard
Click image to enlarge
£73.59 inc VAT
AMD Athlon 64 X2 Dual Core 6000 3.10GHz (Socket AM2) - Retail
£68.99 inc VAT
is that any good as an amd alternative ? plus a lot cheaper :)
Well If you need cheaper you could drop the CPU down as far as an E5200 if you wanted, though obviously you are losing performance in doing so
isn't the e5200 a good overclocker ? sure ive read that .. how much of a performance hit really would there be ?
Yes it is a good clocker and you can clock it back up, however I assume this is a HTPC and they dont handle too much OC'ing very well as they have poor cooling
hmm good point .. wont be much room for the air to move about ... i take it i'll be stuck with the stock cooler for the cpu, as no room for anything else ?
probably better if i went higher spec as it should last me longer ... on 2nd look the original mobo looks the business ... how good is the onboard graphics ?
