I've done a few builds for customers with different boards and there are pros and cons with all the boards I've used.
I'm looking to possibly move to Ryzen myself (spec in sig) and I'm wondering which board is the best for a BIOS that's easy to navigate and use? Also, which company does the most BIOS updates/improvements?
I'll probably move over to M.2 drive from a SSD
I've a few drives I use, ssd and mechanical drives
I'll only use 1 GPU
Looking at a Ryzen 1700 cpu
The last board I used was a MSI Tomahawk 350 and that BIOS was a dog to use :/
For my own use I'd like a board that has got a BIOS that is easy to get around. Easy to tweak settings and will let 3200RAM hold its speed without too much tweaking.
First thoughts was the ROG Crosshair - But it's a little pricey
https://www.overclockers.co.uk/asus...ket-am4-ddr4-e-atx-motherboard-mb-6aa-as.html
That's one I've not used before so I don't know what the BIOS is like on it.
Are there any new boards, released recently, that would be a good recommendation?
I'll only use 1 GPU
