Best monitor for 'around' £200?
1 Aug 2003
I'm in the market for a decent monitor, probably a 22inch one for around the £200 mark. It will be used mostly for graphics work so decent colour reproduction is preferable.
Any advice appreciated.
In you case I think this (Dell 2209WA) is the only one to look at.
It is on budget, uses an E-IPS panel (much better than TN panels on all the competitors) and is generally awesome. The next step up is to this (Philips 240PW9ES) - but its well outside your budget.
