hello People,
Looking for some screen which would be good for my eyes when spend much time in front of it.
I red few things and based on it I get to the conclusion that I should look for IPS monitor with high refresh rate, flicker free and low blue light feature. Not sure if this is completely right.
I am not gaming but decide to get asus vg27aq as this has all of the above. My main thing by the computer is: reading staff and watching movies or sports.
so my question: is there anything better then what I already get?
I have 14 days return policy so I should be ok with it. The only way I can spent some longer time by this screen is on low blue light mode 4, which disables a lot adjustments. I am running it 2560x1440 144hz.
brightness and contrast on my GPU is set on 50%, and contrast on 80 on the monitor setting.
with all of this screen is a bit darkish but not to bad for my liking. I kind of hoping for something better.
So, is there anything better? I need at least 27inch 2k monitor for around £500 (can go a bit over it with something really special), I do not mind bigger screen with 21:9 ratio but it would be probably over my budget
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
