Best Monitor?
4 Mar 2008
Wandsworth
Which is the best monitor size for 2 Palit 9600GT Sonic 512mb's in SLI
And which is the best value for money?
thanks in advance
With those two sli'd you could safely game on most titles at the 1920x1200 mark. Crysis won't be great at that res though, but you can run in a lower res and let the monitor upscale it. Whilst playing you really won't notice the difference.
best fps monitor is 22 inch IiYama E2201W-B1 as it has 0 imput or impout , but note its b1 version not b2 as b2 is totally different.
second best monitor is Samsung SM-226BW 22" that u can get here.
Note: this monitors above is stated to have lowest lag so it is good if you play multiplayer games. but if you looking for image quality or do some kind a graphics work u should get something else
