I have a Magic mouse at home which I use on occasion when I connect the laptop to an external monitor. The functionality is great but I have to say the ergonomics for me, are poor. I do find it too low profile to be comfortable for extended use as well as too small. If you can, give the Magic mouse a try, at an Apple Store perhaps to see if it suits you.
I loved my old Logitech MX518 (yes it's a gaming mouse) for it's comfort and functionality but that is quite old now and I'm sure there are many newer, better models available.
But for a MBP a Magic mouse is perfect. I find them a bit small but they are great for productivity imo and the way they work with a Mac you'd be silly not to!
I personally use Magic Trackpad whenever my work or home Macs are plugged into an external display, I use the gestures a lot and I feel the Magic Mouse is too small to be reliable of lot of them.
For any precise work such as Photoshop I'd say that a Magic Trackpad will be a little fiddly (and pointless as you've already got the same thing built into the machine itself). A mouse would be far better suited.
As for mice...you really ought to go and try. There's only so much we can tell you. I will say that in my personal opinion, the Magic Mouse is one of the worst mice ever created from an ergonomics standpoint.
I too use my Trackpad with the Mac Mini and iMac. The magic mouse is ergonomically horrible and the thing sucks when it comes to gestures. A good wired or bluetooth mouse with the Trackpad is a good combination, using the mouse for doing work where accuracy is required (such as PS) and the Trackpad for gestures and navigation the rest of the time.
I use a magic mouse for most of my design stuff and get on okay with it. You don't hold it like a normal mouse, you just flick it around with the finger tips. Gestures work well for me, and I'd be quite lost without them now.
