Best NB cooler?
4 Jan 2004
¯\_(ツ)_/¯
I can't decide between the Noctua NC-U6 Dual Heatpipe Northbridge Cooler and the Thermalright HR-05.
Which gives the lowest temps? My motherboard is a gigabyte DS3 BTW.
I have a standard HR-05 and I had a few concerns with the way it was mounted. For something tall and heavy on a tower case it could do with being a bit tighter than the spring mounted push pins I've got. Seems to be making reasonable contact though.
Have you looked at the Zalman range at all?
PK!
