best NOD32 settings ?
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Hi folks, gone from AVAST to AVG to AVAST and now to NOD32 which looks to be very good and light on resources :D
Just wanted to check what options people are using for AMON ?
I'm after the best mix of performance but still staying secure so currently have:
On the next tab I have the 2 "potentially..." options unticked too.
Cheers!
The only options I fiddle with are the password and setting up a daily scan.
There's no need to worry about performance with NOD32.
Looks like the 'i don't want to have to do anything' guide. The guide has some good points but i don't favour all those settings.
So i wouldnt call it the ''PROPER'' way at all...... perhaps the word would be ''POPULAR''..
Amidar said:
The bloke who wrote it works for ESET.
And this means what?..... it's the gospel guide of how to setup nod32?....
Agreed it does suggest some very "easy to use" and "safer" ways to use nod, but as i said i simply don't agree with everything suggested.
If it was the "proper" way to do it, why have other options in the first place?..... :confused: lol.... you with me yet?
No problem, just thought you choice of wording as being the ' proper ' way was wrong.
I'm being picky anyway, just ignore me, had a bad day today.... not your fault... ;)
Some of those settings in the guide are a bit off from what I have! - thanks for it though I will have a play :)
AMON has scanned over 11,000 files already and I could not even tell it was doing so, it's faaaaaaaaaaast!
