Best OC Mainboard
1 Feb 2006
Rotherhan, UK
whats the best motherboard for overclocking to go with a Opti 170, must have sata II support and gigabit lan, also onboard sound. looking to spend under £130
Yep, running NF4 ultra d and it supports SATA.
I got an extra 300mhz out of my opteron on this board. Personnaly, if you can afford it, go for the expert, it has a better board layout esp on the chipset... the graphics card go over it so any quiet replacement on the ultra-d is bloody annoying.
is it really that much hastle to fit, u have to do a lot. my asus A7N8X-EDeluxe was just plug it in and away we go
DFI if you will constantly tweak for overcloking
asus if you want good performance out the box and every day. also a little overclocking
i think i want asus for my new board, after going from a headache i just want to relax a bit knowing the thing will load windows at least without spending an hour fiddling memory timings
well im not planning on tweeking, i want to get my Opti 170 upto 2.6 and clock my RAM to whateva i can get out @ 24/7 stable and leave em there
what clocks could i get out of the 170 using a SI-120 with a 120 Delta (yea im mad i know), using the asus, also which asus should i go wi
