Best option for connecting 2x VGA monitors to existing system
21 Aug 2014
Manchester
Morning all,
I'm currently running an AOC G2460P monitor, via DVI-I, to a Gigabyte GTX 970 Windforce.
Over the past weekend I purchased 2 used 19" monitors (Samsung & Benq; low resolution, but fine for cheap secondary displays), both of which only have VGA inputs.
I'd like to figure out the best way to connect each of them, for performance and £ fronts. Would it be best to connect the secondary's to my iGPU (I currently have one of the monitors on the iGPU via VGA - should I simply connect the other with VGA to HDMI to the iGPU, or would it best best to run all of them through the dedicated card?
Graphics card outputs: 1x Dual-link DVI-I / 1x Dual-link DVI-D / 1x HDMI / 3x DisplayPort
Motherboard: Asus Z97 Pro w/ 1x VGA / 1x HDMI
AOC G2460P inputs: 1xVGA / 1x DVI-D / 1x HDMI / 1x DisplayPort
