Best option for pc in campervan?
25 Nov 2013
I have been using a windows 10 tablet connected to a TV via hdmi however its a cheap linx tablet and rather slow. I am wondering if there is better alternative to a tablet or laptop with similar power consumption as a laptop that i can just install and hide away. I only need it for web browsing and watching youtube/netflix.
How much are you looking to spend?
If you want to stick to low power, portable but fair amount of performance GPD do a bunch of devices but they are moderately expensive - I use the GPD Pocket (original version) quite a bit for that kind of stuff.
There are a bunch of cheap generic Windows 10 tablets of varying quality and performance which will also be low power but most are a bit meh.
Most proper laptops will be 2-4+ times the power use even with low power profile in use.
You can get varying micro computers as well such as the various NUC devices but I have less experience with them.
