What is the best out of these?
Gigabyte M27Q - Decent price for what you get
LG 27GL850-B - Great price but older tech, disp port 1.2 and limited to 1440hx
Doyssey G7 - Only VA panel I would go for, good spec but issues with a vesa mounting arm which is a must and also people say curve not so good on a 27
Asus VG27AQL - On paper is a good spec but low frame rates lag
Any other recomendations
Requirements
GSync or compatible
144+ hz refresh rate
1440p
Preferably IPS but will let the G7 in to the mix.
Good range of colour (will use screen for work, games and HD Movies)
Ideally display port 1.4 as I plan not to change the screen for a long time and more likely to further upgrade the PC in the future.
Vesa 100x100 wall mountable that doesn't require modifying the plate on the arm
Requirements
GSync or compatible
1440p
