best pc gamepad?
Caporegime
20 May 2007
Surrey
What gamepads are widely regarded as the best ? I'm looking for a pad to play test drive unlimted,fifa,pro evo,toca race driver 3 e.t.c.
cheers
jt
cheers
jt
I find the best gaming pad are the Sony Playstation pads, get a PS adapter (Super Joy) which plugs into your USB and away you go. I think the pads can be had for £20.
Am using a wireless xbox360 pad with the microsoft PC wireless gaming receiver...
This most be the best gamepad setup i have ever used for PC gaming
Same. Only difference is I am using the wired pad... it rocks :)
360 wired here too! :D
Installed Colin Mcrea Dirt and started to play using the keyboard as it was crashing out whenever i tried to get to the options section. Once i was in game i wondered what the rumbling was... turned out the 360 pad was up and running. No set up required.
Never had a better one. :)
Used the PS2 pad with an adaopter in the past but it can be a little fiddly and unreliable! :(
gt
