- 17 Nov 2018
Hi All,
I'm hoping one of you can help me with my latest venture!
I'm trying to build a very specific machine / Setup and I don't want to get it wrong or waste money where I don't need to.
Recently I have been venturing into the Hyper-V world to virtualise all of my business PCs to one host. I need to be running 10-20 VMs simultaneously 24-7 in order for my business to work correctly and so I have decided it is stressing my current set up a bit and would like to invest in a stand-alone PC to take the load!
Specifically... I would like the machine to be capable of:
- Running up to 20 VMs simultaneously
- Each VM is allocated a dynamic Memory that maxes out at 1GB of RAM and 20 GB on the virtual hard disk.
- It need to be able to run Hyper V ( I had to enable this in my BIOS on my current machine so I assume there are operating systems that don't allow it)
- The machine/setup doesn't have to be used for anything else at all.
I suppose my biggest question is: What exactly do I need here? Do I even need to build an entire PC? or do I just need a few graphics cards in a case? or a hefty CPU? Before I go on to much like I have a clue what I am talking about I built my first PC about two months ago so I am still getting my head around everything, therefore please approach me as if I know nothing/not much at all)
Ideally, I only want to spend about £400-500 but if I can get it cheaper GREAT or if it is more expensive be please be straight with me so I can dig deeper...It is my livelihood after all.
PLEASE HELP!
PLEASE HELP!
