Best place to buy Carpets from?
30 Sep 2005
Hi Everyone,
I'm sure I read on here ages ago people mentioning a really good place to buy Carpets from. Think the general consensus was not to go to somewhere like carpetright as you get ripped off.
any ideas?
Thanks!!
If carpet right do have something you like it will probably be elsewhere cheaper. We are going to have 'gala mineral stripe' for the stairs and hallway, it's £18/m2 from carpet right and £10.40/m2 from flooring megastore.
I get samples of various online shops then order the one I like online
Get my underlay from tradepriced -usually traidaire dreamwalk 11mm
Then get a local fitter.
Bit disjointed but works out much cheaper than high street carpet shops
