- 26 Sep 2005
- Tonbridge, Kent
Recently I have been ripping CD's to FLAC format instead of mp3 as I wanted to get the best out of my (reasonably good) sound system.
True it's difficult to tell a difference from a decent Lame mp3 rip to a FLAC rip, so maybe I'm wasting my time.
But anyway
As I spend a large amount of time commuting, I spend a lot listening to music. I have nice in-ear headphones so it would be nice to listen to my lossless music on the go.
Here is where my problems begin, as i'm trying to find a music player which:
Reasonably priced,
Plays lossless music (or a player which can use Rockbox)
Large capacity (at least 20 gig otherwise what's the point?)
Good sound quality
Small and sturdy
Good battery life.
The first thing I looked at was the Cowon iAudio X5, however after reading a few reviews, it turns out that it breaks easily if dropped and the music navigation (the way it's listed) is as basic as it gets.
All Creatives do not support bit-rate higher than 320kbps
The new iPod Classic whilst having big storage capacity and better battery life, apparently has poorer sound quality than previous generation's (http://discussions.apple.com/thread.jspa?threadID=1126861&tstart=0).
Most other players that support lossless music are either 4 GB or £400.
So really it comes down to either a 80gig iPod Classic (re-ripping everything to Apple Lossless), or the older 80gig 5.5 which i can install Rockbox on.
Any suggestions?
Thanks
Ben
But anyway
Reasonably priced,
Good sound quality
Small and sturdy
Good battery life.
Any suggestions?
Thanks
Ben
