Best power supply for 8400 + 1060 under £50
Caporegime
20 May 2007
Surrey
As the title says I am looking for the best power supply for under £50 to go with a medium range build - z370 i5-8400 and a gtx 1060, just one hard drive, a couple of fans so nothing fancy.
I am guessing 500w would be more than enough (there won't be any overclocking).
Any recommendations?
Not a lot of choice in that price range. A Corsair CX or CXM (Grey label) is probably your cheapest option for something half decent.
If you're still looking, get:
https://www.overclockers.co.uk/supe...us-platinum-power-supply-black-ca-056-sf.html
5 year warranty, very efficient and built on a high performing, well reviewed platform. Yes it is slightly over budget, but it is substantially better than anything just under £50. I would not skimp on the PSU just to save £10.
Currently on offer for £59.99, but this 20% discount ends tomorrow around lunch time.
This would also offer you extra headroom if you wanted to upgrade to a 1070/1070ti/1080 or even the mid-range Volta cards next year
