Best practice when I'm moving my rig?
26 Dec 2008
Cornwall
Hey all,
Moving back up to uni at the weekend and I wasn't sure of the best way to pack my rig for whilst its on the move, I'm thinking draining is going to be the best idea? Only thing is can I reuse the fluid after?
I'd drain, you could probably reuse provided the fluid doesn't get contaminated in any way, though mlwood would be the best guy to advise :)
I just carry mine when moving house. Water and all. How much confidence do you have in the tubes staying attached when you shake it about?
If travelling over long distances I prefer to drain mine - better safe than sorry. Drain the liquid into a sterile water bottle of some description and you should be fine to use it again.
