Best pre-built gaimg PC for under £1000
23 Jul 2012
Hi, am looking for the best spec gaming PC I can get pre-bulit for around £1000.
I'm after PC that will run the lastest games maxed out at 1080p with 60fps.
My budget does not included a monitor but I do need one
Any help would be greatly appreciated, thanks
YOUR BASKET
1 x "Titan 8700i Pulse" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge System £490
1 x Intel 330 Series 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail £81.98
1 x Networking Not Selected £0
1 x System 12 Months Standard Warranty £0
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x No Sound Card Upgrade £0
1 x Opt Out of FREE AV Software £0.01
1 x Sapphire HD 7950 OC 3072MB PCI-Express Graphics Card (11196-01-20G) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £259.99
Total : £934.57 (includes shipping : £15.50).
YOUR BASKET
Is the 7970 worth the extra money?
Hmm, there is a performance difference but at your res then I would say stick with the 7950. But ultimately its your decision :D
The price difference is certainly a lot larger than the performance difference between 7950 and 7970. Also with a 7950 you would have the option of overclocking to near 7970 speeds anyway.
However a good general piece of advice is that you should buy the best single GPU you can afford. So a 7970 would not be a bad option if you really do want the best.
