5 Apr 2007 at 14:24 #1 j0nnyd j0nnyd Associate Joined 1 Apr 2007 Posts 72 hi what is the best pre-built system i can get from overclockers for a budget around £900? thanks
5 Apr 2007 at 14:29 #2 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire better building your own, will save you immense amounts of cash allowing you to build a better system then your budget allows but here is a half decent system that fits your budget http://www.overclockers.co.uk/showproduct.php?prodid=FS-034-OK&groupid=43&catid=781&subcat=
