- 27 Mar 2004
- Between Realities
I know that rule of thumb at the moment is go for a sandybridge\ivybridge. But is that the case with regards to transcoding 1080p content?
I'm not looking for a gaming rig, this is literally going to be a small HTPC running windows 7, It will display directly to a TV using XBMC, and it will transcode content for Xbox 360 and PS3 in other rooms.
I'm looking at the phenom IIs, as I imagine 6 cores in full swing overclocked could do the job flawlessly and for a smaller cost, especially if I go fishing on the second hand market\MM.
No real budget, but I just dont want to be buying a 2500k, if it'll make zero difference to buying a 1055t\1090t\1100t at cheaper cost.
Keep in mind i'm not talking encoding here. So I'm not looking to covert a movie and time it. I just want to sit and watch a 1080p movie with zero buffering on the 360\PS3 regardless of its inital container\codec type
