Best prog for virtual cd drive?
18 Oct 2002
Newcastle, England
Whats the best thing to use because i have an iso i want to mount and not burn. In the past I have used alcohol 120, dameon tools, etc.
Whats the best to use.
Weird I go to install the 64bit version and it wants to install into the x86 program files?
IMPORTANT: when installing daemon tools make sure you UNTICK the seach toolbar option from the install options. DO NOT install this as it install a bunch of crap adware/spyware etc... you have been warned ;)
