Best Program For Temps
21 Apr 2006
UK, Lincolnshire, Lincoln
Dont know if they has been made before, so please remove if it has,
Right,am usein speedfan, and i just wanted to check with a other program that they are the same temps or neally the same..
Cheers
Chopper
TAT and Coretemp are probably the best, for me low temps TAT reads slightly higher, high temps Coretemp reads higher but their pretty close in both cases.
Jokester
Thank you Jokester for your quick reply.
am just gonna search for these's and download
Thank you again
Chopper
Coretemp should work on more recent A64s as well I think?
Jokester
Edit: Ah wait you've got a P4, Speedfan is probably as good as it's going to get to be honest.
heres a screenshot, this is the error i get
:( Chopper :(
Jokester
Yep, works on the x2 939s at least.
speed Fan,Everest all these programms are tottal BS , on IDLE mode i got 38-39 with EVEREST
30-34 with Speed FAn rofl
42-43 with Core Temp and TAT exactly same, so i guuess Core temp and TAT works corectly ,more or less!
iam using AF7 Pro first day today ! a bit disapointed acctualy! Well better than before,but now i am thinking about all thouse reviews how good is AF7 ,and temp drops by20 degrees,well boys i guess you are using cheep programms like Speed Fan!
now after 1 hour running Orthus on max load temps are @ 58-59,before with stock cooler i had 67-69,before idle temps were 55-56 with Core temp,now 43-44! So i guess i wont do my first overclocking another few months until i get better temps ,what do u think guys,can i still overclock ,and corect me please if iam wrong on something!
I like TAT! it over-reads slightly which is nice, and the option to stress the chip for load temps is just groovy, baby!
