BEST PS2 to USB adaptor
Sem
Sem
18 Oct 2002
London
been using the play ps2 to usb adaptor for 3 years now but now its broken i want to get another one but not the same one
with the play adaptor the drivers weren't very good and i didn't install them and the rumble didn't work
this time i want to get one with decent drivers
can anyone recommend any?
thanks
Sem said:
really interested in this item
how are the drivers could you post a screen of the controller config
thanks
It uses the windows default. But you don't use that to set it up for your games.
Once the drivers are installed, you just go in to your game (the game picks up that you have the converter installed) go in to the games controller option, and set it up that way!
I tested it on CSS, HL2 & Madden 07
Don't really play another games really. I don't see why it wont work on any games tbh! Seen as the ps2 pad inst even supposed to work on Madden!
However, the disk that they sent me was the wrong one, they sent me the wrong one by mistake :o However they emailed me the drivers within 30 minutes..
If you buy it let me know and I will email you the drivers just in case :)
Anyways heres the config you requested!
nintenjo said:
Does it work with light-guns and the Guitar Hero Guitar?
No idea mate, don't have them.. However I don't see why it wouldn't if it has the same ps2 plug at the end.
However you can always ask the guys who sell the item :)
