Best psu out of these 2
6 Feb 2004
Rugeley
I have got a choice of 2 of these not sure if to go for the 700w or the 600w it seems for £1 more the 700 would be more logical but the 600w must be of better quality maybe ? anyway here they are, its running a q6600@ stock atm, 2 gig ram, 3 harddrives and the usual stuff and a 8800gts 640, but i want to put something like a 4870 in soon.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-031-OC&groupid=701&catid=123&sub
http://www.overclockers.co.uk/showp...-OC&groupid=701&catid=123&subcat=1098cat=1098
Going to order tomorrow just wondering which is best really.
Looking at both PSU specs, the 600 watter is modular, the 700 watter is not.
Either will power your rig fine.
The 600 watter would be better if you have a small case & you want less cables to tuck away.
What does it being modular mean??
It means you only plug in the cables you need to use. And they're generally braided and look nice.
OCZ ModXStream Pro 600w for the win! (for some reason the abbreviation of for the win gets starred out?! :S)
