best pump a res to use
6 Jun 2014
kettering
YOUR BASKET
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £124.99
1 x EK Water Blocks EK-D5 Vario X-TOP - Acetal (incl. pump) £89.99
1 x EK Water Blocks EK-FC780 GTX Ti - Acetal+Nickel £79.99
1 x EK Water Blocks EK-Supremacy Clean CSQ - Gold £69.98
1 x EK Water Blocks EK-RES X3 250 Reservoir £51.98
1 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99
1 x Three Fan Bundle - Corsair SP120 Quiet Edition Fan 3 pin £26.99
1 x Akasa 5.25" FC Six Channel Brushed Aluminium Fan Controller (AK-FC-08BKV2) £24.98
1 x EK Water Block EK-FC780 GTX Ti Backplate - Gold £24.95
1 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting Six Pack - Gold £24.95
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
4 x Monsoon 16/10mm (OD 5/8) Rotary 90° - Gold £8.69 (£34.76)
4 x Monsoon 16/10mm (OD 5/8) Rotary 45° - Gold £8.69 (£34.76)
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
1 x Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit £6.98
1 x XSPC Hose Cutter (0-25mm) £6.95
1 x XSPC LCD Temperature Sensor (White) V2 + G1/4" Plug Sensor £5.99
3 x Primochill Primoflex Advanced Tubing 16/11 - White £5.99 (£17.97)
4 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting - Gold £4.99 (£19.96)
1 x XSPC PSU Bridging Connector (24 Pin) £1.99
Total : £745.62 (includes shipping : £13.75).
does this basket look better but in the 750d where can I hide the pump ?
I must admit I've not seen many people use the pump you've selected, more often than not people choose either the one 'thomasjarvis52' has selected or the smaller one 'BattFink' has linked two. Personally I'd be tempted to go for either of those two, rather than the one you picked.
From what I've seen that case has a pretty big window mate, so hiding the pump will be extremely tricky, unless you make a shroud to hide it.
