- 9 Jun 2011
Hi can someone tell me the best fan for WC rads silence wise, additionally what the best bang for buck fan would also be
Depends what speed you run them at, I'm using Noctua's at around 600rpm and they are silent.
This rad is not good for 600rpms (unless idle). It cools well but at 1200rpms +.they're for a EK PE 360 rad I value silence and low temps so yeah 600rpms which ones do you suggest
