best quiet socket 939 Heatsink/fan
22 Apr 2003
Button Moon
what is best socket 939 Heatsink/fan, it will be cooling an overclocked Fx57.
Preferably silent, or near.
thanks
Arctic Cooling Freezer 64 Pro
I can't hear mine over my very quiet case fans. :) It also one of the best AMD Athlon 64 coolers around at the moment.
SiriusB
Yes I was thinking the same, i've got a arctic cooler freezer 64pro and its really loud (VF900,Silenx,Seasonic user).
Whats the most silent performing with good performance, am I right in thinking a SI120 would be best with say a big 120mm Silenx far or the sorts.
I dont like the look of them lol, I like the thermalrights because you can put your own spec fan on.
EDIT: just seen it has a 16dba fan, looks interesting hmm.
scythe ninja is the best cooler, especially if you like silence. well, the tuniq tower is better, but its more expensive and harder to find.
Big typhoon is really quiet even on max speed.
really great cooler!!
Artic cooler 64 was also impressivley quiet when i built a mates pc recently.
