Best racing wheel under £50???!?!?
Nothing new costing £50 with pedals, shifter and wheel itself would be worth owning. Would break in a month.
Second hand for sure with that budget.
Save your money & get a Logitech g27 you will not be disapointed or get second hand if you cant wait
Sorry guys, I don't want to spend too much on a wheel :(
maybe the logitech driving force pro
Logitech DFP will be your best bet, second hand they're £50 ish :)
i've had mine for 5 years and it doesn't feel much worse than my mates new one!
( I used be on it since i got home from school till i went to be for 2 years when i first got it, an used it around 5 hours a week since that)
Logitech Formula Force Ex. I bought one few years ago for £35, good value quality piece of kit, not sure if they still make them but worth a look. I hardly use mine anymore though as I lost interest in racing games.
Leave the gear box, don't even use manual because I am too rubbish :rolleyes:
Any without that supports (or works with) Dirt Showdown, F1 games etc...
Thustmaster F430 around £70 new but probably could get one on the bay for under £50. Wheel is pretty good and the pedals are so much better than the DFGT ones.
