Definetly Thermochill. Just make sure you buy a new one and not an older model. The spacings are different and the old ones wont mount in your case easily.
Not to sure i would honestly like to know if anyone has been able to fit the PA140.3 in the top of a cosmos 1100 the PA120.3 fits fine i read that the 140.3 performance wise is on par with the PA120.4 .. an upgrade might be in order soon as when i add in two 6870s (when out) i want to add them to my loop.
