Best RAM for 5900X
30 Jul 2007
Lincolnshire
Hi guys,
Hoping for some advice from the memory gurus. So I’m looking to get a 32GB RAM kit. I initially looked at a G.Skill Trident Z Neo 32GB (4x8GB) 3600 C16 kit - then realised it can strain the CPU more and harm any OC I try.
So I’ve moved onto a G.Skill Trident Z RGB 32GB (2x8GB) 3200 C14 kit. Which is supposedly guaranteed Samsung B-die. Specifically it’s the F4-3200C14D-32GTZR model.
Now is this the best kit I could get for £250 delivered? It’ll be paired with a 5900X and Asus Prime X570 Pro. Should I expect it to reach 3800-4000MHz C14/16?
Just really after the best performance and bang for buck. Without spending stupid money. Appreciate any advice :)
Thanks
